Retired_Member
Sep 25, 2019Orbi RBR50 bricked during update to 2.3.5.30
Router was on firmware 2.3.1.60. I downloaded the latest firmware update, 2.3.5.30, and via Ethernet cable. Router was performing the update and got stuck for a very long time. The router was unrespon...
Retired_Member
Apr 21, 2020
BoilerPlate wrote:Your "bothered" by users trying to help others out though. Something the forum is here for. Help each other out. Not to troll or badger users.
Bothered..? Not bothered, more like concerned. You appear not to have been around long enough to witness the true 'hoarding' of this community of one individual, all the while spewing bogus info. NG support has gone on record advises people, that if your system works, leave it alone.
The one user in particular has long advocated his/her life on the edge and the joy experienced of playing beta tester or some sort of NG employee...??
I feel most folks in here don't want to be treated like a guinea pig, but would rather seek a clear and concise explanation (not copy/paste) and then told the truth concerning firmware updates. NG used to push ALL updates. Then the whining began. So therefore, what you have today is the only updates that are pushed are those that contain critical updates. All others should be viewed as highly risky.
You my friend may not agree with my position and that's fine. Then may I suggest you support the opposing side and leave my posts to those who seek the truth.
Have a great day.
BoilerPlate
Apr 21, 2020Apprentice
Well what users think and feel isn't of any of your concern. You have no "unfounded" information regarding what other do and do not think about when posting in the forums. From all the resolved posts seen, seems like most of the users are happy with what the community and comunity users are doing for them. No body asked you to be concerned and speak for everyone in the forums. If NetGear has problems with your one user you seem to dislike and bager all the time, I would think he wouldn't be posting like they do. You are not one to hold judgement or any one cirtical. The forum community is no the place for that. Too bad you can't understand that.
Good Day.
- BigRuneApr 21, 2020ApprenticeWell advice to not do manual updates of Orbi is good advice, unless you experience problems with current fw.
Time to cool down đ boys, nobodyâs gonna win.
