retiredat44
Dec 04, 2021Initiate
Orbi RBR50 bricked
Bricked, shut down, and tried everything in the forums, eveyrhting, the hard reset didn't help, the TFTP could not connect properly. I have decades of computer experience. The RBR50 and rbs50 are exp...
Dec 05, 2021Guru - Experienced User
Have you tried swapping a power supply from one of the satellites to the router?
It wouldn't be the first time I'd seen a power supply cause issues.
And if the router isn't work, the satellites are effectively worthless.
retiredat44
Jun 28, 2022Initiate
sorry, I just saw your answer.. No, I did not swap the psu out (I may have, but cannot be absolutely sure as it has been a while)... I considered throwing the pos out or selling it... I put to much time in it... I tried using the serial connection and different computers and operating systems to try to get it working folowing the dircetions posted all over the internet to fix it.. nothing helped...
