Johnstac
Sep 17, 2019Aspirant
Orbi RBR50 broadcasting its own network as an access point?
I installed this or be purchased from Costco about a year ago. It has worked perfectly but recently I tried to connect to my TiVo and was unable to do so. In a TiVo forum, it was suggested that I...
Sep 18, 2019Guru - Experienced User
Modem Combo Units:
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
Johnstac wrote:I installed this or be purchased from Costco about a year ago. It has worked perfectly but recently I tried to connect to my TiVo and was unable to do so. In a TiVo forum, it was suggested that I may have a double NAT situation. Someone provided some documentation on changing Orbi from a router to an access point. That worked successfully no problem. Here is my concern. When I changed Orbi to an access point, I went back to the Frontier router and turned on the broadcasting of its SSID. I thought that once Orbi became an access point it would cease to broadcast ORBI01, etc. I thought it would begin broadcasting the frontier routers network. What I would like to know is whether I can turn off the frontier routers broadcasting of its SSID and use the ORBI01 that is still being broadcast by Orbi. Thanks for any help with this.
