pcs1001
Jul 27, 2017Aspirant
Orbi RBR50 can not set parental settings with Genie App
I have enabled Parental Controls and setup a Custom filter in Netgear.opendns.com. Everything was working for a short time but when I go into the iOS Genie App and try to set individual devices to Mi...
pcs1001
Aug 07, 2017Aspirant
Yes, I have tried to reinstall the app. The only way I can get it to work is to install the previous firmware. It then seems to work for a bit until it automatically updated the firmware again. The factory reset also works for me, but after setting the parental settings on a few individual devices with the app it brakes again.
