nDrewk123
May 04, 2018Follower
ORBI RBR50 Cannot keep connection
CANNOT keep a connection, keeps going offilne every few seconds.
running firmware 2.1.4.10 says this is up-to-date.
internet connection is fine, tested my laptop (macbook Pro) direclty to my modem.
It is def the router.
Anyone else????
HELP!!!!!!
- ZdmanGuide
Do you have any orbi satellites and if so, how are they connected (wired or wireless backhaul). I had a wired satellite and latest firmware caused continuous network issues.
Was a Factory Reset performed before and after any firmware updates then set up from scratch? if not, please try this on both router and satellite.
What ISP Service do you have? Cable or DSL?
What ISP Modem Mfr. and model # do you have?
What ISP Modem service link speeds UP and Down do you have?Any other wifi neighbors near by? if so, how many?
Anyone else????
HELP!!!!!!
