Wongie
Oct 22, 2018Aspirant
Orbi RBR50 can't access some web sites after changing service provider
I have been using Orbi fine for many months.
Then I changed my Fibre provider from Sky to TalkTalk.
TalkTalk defaults to stop all traffic from sites it doesn't recogonise. I had to go in...
Wongie
Oct 23, 2018Aspirant
Many thanks for your reply.
I'm sorry but my knowledge is very limited! What do you mean by this:-
What FW is currently loaded?
I have reset both the TalkTalk Router and Orbi and set up the Orbi again after reboot but no luck.
It is not much help to suggest I should of contacted TalkTalk before I connected the Orbi, that ship has sailed and I have changed supplier twice before without any problems.
Retired_Member
Oct 23, 2018
What FW is currently loaded? Loaded as in your Orbi router and Sats. Login to the Orbi to find out.
What is the Mfr and model# of the ISP modem the NG router is connected too? This goes back to my question...
I have reset both the TalkTalk Router and Orbi and set up the Orbi again after reboot but no luck. If you're using a TalkTalk router AND the Orbi router you must place one in the Acces Point (AP) mode. You can't run 2 routers doing the same job.
You can still contact TalkTalk and ask for recommendations.
