rellimit
Oct 19, 2022Aspirant
Orbi RBR50 can't connect to Google sites unless on VPN
We have an Orbi RBR50 with Satellite. In the last few months we have repeatedly and consistently seen an anomaly with this system. When using our Orbi wifi, we cannot connect to specific Google sit...
- Oct 24, 2022
Hello rellimit,
Welcome to the NETGEAR Community!
I understand that you are having issues accessing certain google sites with your RBR50. Changing the DNS of your RBR50 has been proven to solve website access issues. Please use the DNS IPv4 address 8.8.8.8 as the primary and 8.8.4.4 as the secondary DNS to resolve this issue.
To change your DNS please navigate to Orbilogin.com >ADVANCED >Internet Setup >Select "Use these DNS Servers > Then input the primary and secondary DNS IPv4 addresses in the boxes on the far right.
Let me know if it works as soon as possible!
Best,
Kevin
Community Team
Oct 19, 2022Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Do you have Armor or Circle enabled on the Orbi system?
