ralphp21
Aug 22, 2018Aspirant
Orbi RBR50 Can't Download Firmware
Hi. My iPhone X Orbi app won't connect to my home network but I'm able to connect to the router via remote management. However, when I go to Router Settings, there is no "Update Firmware" or "Search For Firmware Update" option, only a reboot option. How can I get the latest firmware update onto my router?
Thanks in advance for your help.
Sort By
I recommend using a wired PC connected to the router and use IE11 or FF browser and manually download the FW files from NG support site and manually install the files. Update the satellite(s) first then the router.
- ralphp21Aspirant
Will do. Thanks for the quick response.
What Fw is currently loaded?
- ralphp21Aspirant
2.1.4.10
Ok, should be good to manually upgrade to v.16 if thats what your doing.
