WelshKim
Apr 21, 2020Aspirant
Orbi RBR50 connected on app and pc is online but it says I'm not connected?
I'm trying to see if my Orbi is already in AP mode, but cannot log into Orbilogin.com to find out? It says Im not connected to the Orbi network although I am. Everything else works online and my Orbi...
- Apr 21, 2020
What is the Mfr and model# of the Internet Service Providers modem/ONT or host router the NG router is connected too?
Look at the connected clients list on the main host router to see the IP address of the RBR in AP mode. Use this to log into the RBRs web page in AP Mode.https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point
What is the distance between the router and satellite(s)? 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-routerWhat channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?Be sure all wifi radios are disabled on the host router.
Apr 21, 2020Guru - Experienced User
- WelshKimApr 24, 2020Aspirant
Thank you again. Im not sure what I did exactly but i found your reply to another person offering the advice below and it seems to have worked!
I live in 2100sq ft house on 3 levels. The Orbi router is on 1st floor and 2 satellites on ground floor and 2nd floor. The house is fairly open plan so not too much to block the signal.
I changed the networks and fiddled with a few of the settings and somethiong in that seems to have done the trick.
Thank you so much, i really didnt know what to do. Now I just have to try to get my Sonos speakers back online as they have almost all disappeared with all the changes ive made.
I wonder if the sonos community will be as helpful.....
THANK YOU!!
