MattDJUK
Jul 30, 2023Aspirant
Orbi RBR50 Connection Issue (DHCP??)
On FW 2.7.4.24 Hi all I have an Orbi system (1 router and 2 satellites - which are CAT7 wired). The main Orbi router is wired to my ISP router. No problems with it for the last 3 years at all ...
KevinLiT
Jul 31, 2023NETGEAR Moderator
Hello MattDJUK ,
Welcome to the NETGEAR Community!
It is best to use your Orbi router in access point mode because it enables your entire network to use one network address. Using your Orbi router in router mode separates your Orbi network from your ISP network.
Please do the following to fix this issue:
Factory reset your Orbi router.
Switch the mode from router mode to access point mode.
Then add your CCTV devices to your network.
Please navigate to the link below for instructions on how to correctly:
https://kb.netgear.com/31486/How-do-I-reset-my-Orbi-system-to-factory-default-settings
Please navigate to the link below for instructions on how to change your Orbi router from router mode to AP mode:
How do I configure my Orbi router to act as an access point? | Answer | NETGEAR Support
Best,
Kevin
Community Team
