rkarjadi
Oct 01, 2022Aspirant
Orbi RBR50 Connection Issues - AX201 160 MHz
I've been having WiFi connectivity and internet issues when trying to connect to my Orbi RBR50 from my new PC that has an Intel(R) WiFi-6 AX201 160 MHz adapter in the motherboard. All other devices c...
Oct 01, 2022Guru - Experienced User
I'd try some advanced adjustments on the adapters properties to see if you can tune that adapter in. Make sure it's backwards supporting of 5Ghz AC mode. Most AX adapters should be and include support for AX and 6Ghz depending on adapter.
Make sure drivers are up to date on it as well.
Try a different adapter.
Ya, 160Mhz is only supported on the 5Ghz wireless backhaul between the RBR and RBS. Not user accessible.
