MicahD
May 04, 2018Star
Orbi RBR50 constant "Resolving host" errors across all browsers
Like subject says, lately (past 10 days or so) I get constant "Resolving host" messages when visiting websites AND when trying to go to orbilogin.com to adminster my router. The hangtime for these w...
MicahD
May 04, 2018Star
PS: Orbi system is updated to latest firmware as of 05.03.18
- MicahDMay 04, 2018Star
No one can help with this?
What is the point of a $350 wifi system when it slows my wifi connection to a crawl with "Resolving host" issues constantly?
- DarrenMMay 04, 2018Sr. NETGEAR Moderator
Do you have circle enabled? if so try to disable it and see if anything loads. also you may want to power cycle your modem and the orbi router.
DarrenM
- paikman8May 05, 2018Aspirant
There is clearly an issue between Circle and the latest Orbi firmware that is killing perfromance. I can enable the opendns parent controls and have no issues, but with Circle on websites like mlb.com, samsclub.com and others will not load all background graphics or flash. What is the status of a new firmware update to correct this mess?
