chris_v
Oct 06, 2019Tutor
ORBI RBR50 crashes constantly - kernel panic log
I have an Orbi RBR50 with one satellite connected (RBS50). The Router crashes every 30-120 mintues - depending on usage. It seems to fix itself after 5 minutes or so until it happens again. It's runn...
- Oct 09, 2019
I haven't done the satellite reset yet but I can confirm the system is running perfectly sinceI turned circle off. I would love to have it back on though, it managed the kids access really well.
Oct 06, 2019Guru - Experienced User
Has a factory reset been performed and setup from scratch since last FW update?
Does the RBR crash still if you temporarily turn OFF the RBS?
What is the distance between the router and satellite(s)? 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
