chris_v
Oct 06, 2019Tutor
ORBI RBR50 crashes constantly - kernel panic log
I have an Orbi RBR50 with one satellite connected (RBS50). The Router crashes every 30-120 mintues - depending on usage. It seems to fix itself after 5 minutes or so until it happens again. It's runn...
- Oct 09, 2019
I haven't done the satellite reset yet but I can confirm the system is running perfectly sinceI turned circle off. I would love to have it back on though, it managed the kids access really well.
ekhalil
Oct 06, 2019Master
How do you see it’s crashing?
Please describe what happens to Satellite and to devices when Router crashes.
How could you collect logs from a crashing Router?
- chris_vOct 07, 2019Tutor
Ekhalil, technically it's not crashing, although I thought it was and the effect was the same. In terms of logs, I just turned on logging from the debug page.
