chris_v
Oct 06, 2019Tutor
ORBI RBR50 crashes constantly - kernel panic log
I have an Orbi RBR50 with one satellite connected (RBS50). The Router crashes every 30-120 mintues - depending on usage. It seems to fix itself after 5 minutes or so until it happens again. It's runn...
- Oct 09, 2019
I haven't done the satellite reset yet but I can confirm the system is running perfectly sinceI turned circle off. I would love to have it back on though, it managed the kids access really well.
Retired_Member
Oct 07, 2019
chris_v wrote:I have an Orbi RBR50 with one satellite connected (RBS50). The Router crashes every 30-120 mintues - depending on usage. It seems to fix itself after 5 minutes or so until it happens again. It's running the latest firmware (V2.3.5.30). I have the debug files during the time it happened wif someone can help.
Cheers
Chris
Get rid of (V2.3.5.30)
- ekhalilOct 07, 2019MasterDo you have wireless or wired backhaul?
v2.3.1.60 as well as 2.3.5.30 had the same issue with Satellite connectivity. This is probably the issue you're facing. I used to do the following to get around this issue:
- Switch off the Satellite
- Go to Attached Devices in the web GUI and click on the "Disconnect" button beside the Satellite in questions
- Turn on the Satellite and use a paper clip to factory reset the Satellite
- When the Satellite is up after factory reset, press the Sync button on the Satellite (if you have wired backhaul then keep the Ethernet cable to the Router connected while doing the sync) and then press the Sync button on the Router
- When the Satellite is added after this procedure it should behave correctly.
Good luck!
- chris_vOct 09, 2019Tutor
