valentinul
Apr 08, 2020Aspirant
ORBI RBR50 crashing
Hello everyone, I've bought an ORBI RBR50 a couple of months ago and for some reason after the latest update (V2.5.1.8) the router crashes every second day or so.... I've did an reset on the ...
Apr 08, 2020Guru - Experienced User
Did you reset the router as well? If not, try this on the RBR...
You can try Voxels FW for Orbi:
https://community.netgear.com/t5/Orbi/Voxels-FW-available-for-50-series-Orbi-only-available/m-p/1883615#
You can revert back to stock FW if it doesn't work out for you.
valentinul wrote:Hello everyone,
I've did an reset on the satellite as I was reading this forum and this was a suggestion....now I'm thinking of downgrading to the previous version -> 2.3.5.30
Anyone else having this kind of issues ? If yes, any fix available ? Ideas?
Thank you!
br
valentin
