aznrabbitz's avatar
aznrabbitz
Follower
Nov 19, 2020
Orbi RBR50 Cut off randomly and reboot by unplug flashes white ring then goes dark and cuts off
The RBR50 all of a sudden cut off around 3pm today and the light on the main unit just went dark. Try rebooting it multiple times but it will flash the white ring and internet would come back but then it stops flashing and goes dark again and internet cuts off again. Not really sure what to try here, any suggestion would be awesome.
1 Reply
  • FURRYe38's avatar
    Power OFF The RBR, disconnect the cable from the yellow internet port in back of the RBR. Power ON the RBR. The RBR should flash WHITE, then slowly pulsate WHITE then turn PINK. Does this happen?
    What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
