Kanhaiya
Feb 13, 2020Aspirant
Orbi RBR50 Daisy Chain limit
Hi, I want to daisy chain a new satellite I purchased (RBS50) to my existing setup router>satellite1>satellite2 (RBR50 setup) However I’m unable to do so, The satellite gets connected to the router ...
CrimpOn
Feb 13, 2020Guru - Experienced User
The Orbi usually comes from the factory with "Daisy Chain" enabled, but it would be useful to check.
On the Orbi web interface, the Advanced Tab, Advanced Setup, Wireless Settings there is a box "Enable Daisy Chain Technology" that should be checked.
After the satellite has been sync'd to the router, I would power it off and move it close to the existing satellite, then power it on. It should sync with the satellite over the router at that point. Then, move it to its final location. The final location has to be close enough to the satellite to get a good signal (Blue Ring light).
- KanhaiyaFeb 13, 2020Aspirant
ah, thanks! Will try it out and let you know how it goes.. :)
- KanhaiyaMar 28, 2020Aspirant
well i reset the new sattelite multiple times, it gets conntected to the router but when i move it to its final intended location, it doesn't connect to any other sattelite
My current setup has 1 router and 2 sattelites, connected as below across 2 floors
Router > Sattelite 1 > Sattelite 2
I want the 3rd sattelite i'm adding at the end of the chain like so:
Router > Sattelite 1 > Sattelite 2 > Sattelite 3
BTW i checked and Daisychain is enabled on the Netgear Webinterface, please help..
- FURRYe38Mar 28, 2020Guru - Experienced User
When the 3rd Satelite is on and online, reboot the RBR while leaving the RBSs on. Does the 3rd RBS connect to any of the other RBSs?
What is the distance between the router and satellite(s)? 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-router- KanhaiyaMar 29, 2020Aspirant
hey, rebooted the RBR but the 3rd still didn't connnect.
Also the 3rd Sattelite connects to others, i just interchanged the 2nd sattelite with the 3rd one (like so: Router > Sattelite 1 > Sattelite 3 > Sattelite 2) and its working fine but now the 2nd sattelite is not working.
Note: I am not using a hub-spoke connection of Sattelite to Router, only 1 sattelite is connected to the Router and the other sattelite is connected to the first one [Router > Sattelite 1 (connected to router) > Sattelite 2 (connected to first sattelite) > Sattelite 3 (want it to be connected to Sattelite 2 but its not working!]
The first sattelite is about 25 ft away, the 2nd satt is within 20 ft (vertical distance, 1st floor) from the first and same for the 3rd sattelite from the 2nd sattelite (3rd satt is on 2nd floor). 2nd and 3rd Satt are near the stairs and not too much interference in range.
