Kanhaiya
Feb 13, 2020Aspirant
Orbi RBR50 Daisy Chain limit
Hi, I want to daisy chain a new satellite I purchased (RBS50) to my existing setup router>satellite1>satellite2 (RBR50 setup) However I’m unable to do so, The satellite gets connected to the router ...
Kanhaiya
Mar 28, 2020Aspirant
well i reset the new sattelite multiple times, it gets conntected to the router but when i move it to its final intended location, it doesn't connect to any other sattelite
My current setup has 1 router and 2 sattelites, connected as below across 2 floors
Router > Sattelite 1 > Sattelite 2
I want the 3rd sattelite i'm adding at the end of the chain like so:
Router > Sattelite 1 > Sattelite 2 > Sattelite 3
BTW i checked and Daisychain is enabled on the Netgear Webinterface, please help..
Mar 28, 2020Guru - Experienced User
When the 3rd Satelite is on and online, reboot the RBR while leaving the RBSs on. Does the 3rd RBS connect to any of the other RBSs?
- KanhaiyaMar 29, 2020Aspirant
hey, rebooted the RBR but the 3rd still didn't connnect.
Also the 3rd Sattelite connects to others, i just interchanged the 2nd sattelite with the 3rd one (like so: Router > Sattelite 1 > Sattelite 3 > Sattelite 2) and its working fine but now the 2nd sattelite is not working.
Note: I am not using a hub-spoke connection of Sattelite to Router, only 1 sattelite is connected to the Router and the other sattelite is connected to the first one [Router > Sattelite 1 (connected to router) > Sattelite 2 (connected to first sattelite) > Sattelite 3 (want it to be connected to Sattelite 2 but its not working!]
The first sattelite is about 25 ft away, the 2nd satt is within 20 ft (vertical distance, 1st floor) from the first and same for the 3rd sattelite from the 2nd sattelite (3rd satt is on 2nd floor). 2nd and 3rd Satt are near the stairs and not too much interference in range.
- FURRYe38Mar 29, 2020Guru - Experienced User
Distance maybe too close. 30 feet is recommended in between RBR and RBSs
- CrimpOnMar 29, 2020Guru - Experienced User
Kanhaiya wrote:hey, rebooted the RBR but the 3rd still didn't connnect.
The original question may be valid, "How many satellites can be in a "Daisy Chain?" You may be the first person to attempt this configuration. I seriously doubt that feet of separation affects whether satellites will "sync" or not. After all, we routinely advise people to place satellites "in the same room" as the router during the initial setup, or when first attempting to switch to ethernet backhaul. "Too close" certainly has an adverse effect on (a) overall coverage area and (b) interference between units, but for the backhaul radios, probably "closer is better."
I doubt that back in 2016 when Netgear was designing this product they envisioned customers stringing three satellites in a row.
Alas, unless another user has three satellites and wants to perform an experiment, only Netgear engineering can answer the initial question ("how many?"), and they do not participate in community forums. (Maybe their managers expect them to work on assigned tasks rather than spend hours poking around in user forums.)
