computersteve
Aug 09, 2020Apprentice
Orbi RBR50 daisy chain not working good with RBS50Y
I have an RBK53 system.. Both my RBS50 satellites (Ethernet Backhauled) are closer to the RBS50Y (Outdoor Satellite). Still the RBS50Y decides to connect to the RBR50 (orbi router) instead of daisy ...
Mstrbig
Aug 09, 2020Master
Did you check to see if daisy chaining is turned on or off?
Have you reset the RBS50Y and tried resetting it back up?
