tagteam
Jan 25, 2024Virtuoso
Orbi RBR50 Dead (Wireless)
Just a datapoint. My 7+ year old RBR50 just flat out died with respect to wireless functionality. As for ethernet, it appears to be fine. However, absolutely no wireless signal after recycles, re...
- Jan 26, 2024
It is nice having a couple backups! Having 2 RBR50's sitting in a closet makes some nice redundancy. I wouldn't even working about checking into fixing the first if you had 2 backups. If the first lasted 7 years, by the time you need the other backup, it'll be time to upgrade.
Jan 25, 2024Guru - Experienced User
Did you try reinstalling the firmware? Or a different firmware?
not saying it'll fix it and since you have a backup, might not be worth the time on an older system.
tagteam
plemans wrote:Did you try reinstalling the firmware? Or a different firmware?
Yeah, thanks. I tried everything I could think of, including a total reset and reinstall (in fact, I installed 4 different revisions). Nothing.
Kind of strange since there were no power issues whatsoever and even the old, original power supply worked with the other RBR50. I swapped it out anyway, but I literally racked by brain, and spent the most of the day and into the evening trying to fix the old router. No radio!
- FURRYe38Jan 25, 2024Guru - Experienced User
Can try Voxels FW to see if that might kick it back:
Last resort would be 30-30-30 reset.
- tagteamJan 25, 2024Virtuoso
Thanks but, all things considered, I'm fairly confident this is a hardware failure.
Zero radio signal and LED on the top is simply dead while ethernet works just fine. Anyway, the thing is toast at this point since the new setup is working great.
Further, I still have another, unused and never set up, RBR50 (don't ask why I had two backups - lol).
So, if the current RBR50 fails, then the backup gets placed into service and I start looking at quad band. 😉
Might go find a used RBR50 on places like ebay or shopgoodwill.
Or maybe time to find something newer.
Good Luck.
