tagteam
Jan 25, 2024Virtuoso
Orbi RBR50 Dead (Wireless)
Just a datapoint. My 7+ year old RBR50 just flat out died with respect to wireless functionality. As for ethernet, it appears to be fine. However, absolutely no wireless signal after recycles, re...
- Jan 26, 2024
It is nice having a couple backups! Having 2 RBR50's sitting in a closet makes some nice redundancy. I wouldn't even working about checking into fixing the first if you had 2 backups. If the first lasted 7 years, by the time you need the other backup, it'll be time to upgrade.
Jan 25, 2024Guru - Experienced User
Can try Voxels FW to see if that might kick it back:
Last resort would be 30-30-30 reset.
tagteam
Thanks but, all things considered, I'm fairly confident this is a hardware failure.
Zero radio signal and LED on the top is simply dead while ethernet works just fine. Anyway, the thing is toast at this point since the new setup is working great.
Further, I still have another, unused and never set up, RBR50 (don't ask why I had two backups - lol).
So, if the current RBR50 fails, then the backup gets placed into service and I start looking at quad band. đ
- FURRYe38Jan 25, 2024Guru - Experienced User
Might go find a used RBR50 on places like ebay or shopgoodwill.
Or maybe time to find something newer.
Good Luck.- tagteamJan 25, 2024Virtuoso
FURRYe38 wrote:Might go find a used RBR50 on places like ebay or shopgoodwill.
Good Luck.Thanks.
I pretty well fixed here for the time being with my (replaced) RBR50 and another spare in my closet.
If I have to pull out the spare in the near future, then I'll be looking at picking up the 960 series or perhaps even the 970.
- plemansJan 26, 2024Guru - Experienced User
