builder3303
Dec 01, 2021Aspirant
Orbi RBR50 Device Limit
Hi Guys, In past I opened the Discussin about lossing my IoT devices on my network https://community.netgear.com/t5/Orbi/IoT-connection-issues/m-p/2137256#M125630 Well, on that discussion...
Dec 01, 2021Guru - Experienced User
The router maybe maxing out with it's devices and total connections.
What is the default IP address pool size range set on the RBR? .1.2 thru .254?
What happens if you change this pool size to 1.100 to .200?
What kind of devices do you have connected? Any of them like printers, storage,controllers or cameras? Something to help alleviate this issue is to set a static IP address ON these devices out side the smaller IP address pool, that don't need much or any router management.
