builder3303
Dec 01, 2021Aspirant
Orbi RBR50 Device Limit
Hi Guys, In past I opened the Discussin about lossing my IoT devices on my network https://community.netgear.com/t5/Orbi/IoT-connection-issues/m-p/2137256#M125630 Well, on that discussion...
builder3303
Dec 05, 2021Aspirant
Hello,
Sorry my delay answer you and give more infos to try help me find one solution.
I put the wireshark and one draw of my equipments layout (I'm sorry about my rudimentar draw, if you have any any doubts please be my guest to question.
https://drive.google.com/drive/folders/1IOmjFNZrlysAc9xsiP1quwXfb8HPN3HW?usp=sharing
I have done the wireshark capture in one laptop with DCHP and I'm connected to device 1 (check the draw to understand the numbers), I can hadle with all my devices that are in device 1 and device 2, but I can't access to the devices that are in device 4.
I opened a device that I have access to in the browser and pinged and tried to access a device that I do not have access to via RDP.
I think you can check the IPs on capture,
192.168.1.21 with access
192.168.1.186 no access
192.168.1.2 no access
I don't have any equipment connected to satellite 3, this has the objective of intensifying the signal between 1 and 4
I hope it helps.
Thanks
CrimpOn
Dec 05, 2021Guru - Experienced User
The drawing shows two RBR50 routers. Are they connected, or are they separate systems with separate ISP connections?
The Wireshark capture showed only two DHCP packets. (In the upper left, enter dhcp in the display filter.
- builder3303Dec 05, 2021Aspirant
The router you're seeing is the same, one is the project floor and the other the building floors, my apartment, my mom apartment and my office and all the VMs, Homoassistant server, etc are in my office.
ok, but you saw any packet errors to the IPs i gave yo you?
Thank you
- CrimpOnDec 06, 2021Guru - Experienced User
Thanks for the information. Would it be convenient to make a rough pencil drawing of
- How all the equipment is connected?
- Where the device running Wireshark is connected?
Wireshark has to be in 'promiscuous mode' to capture packets that are intended for other devices. This is often defeated by network switches which 'know' where certain MAC addresses can be found and send packets only to the switch ports that lead to those devices.
Going back to the first post:
"If I use fixed IP (on my laptop for example) I can connect and have internet, but I can't comunicate with other devices, por example NAS server! Btw the NAS Server is connected to another satellite!"
If devices are in the same IP subnet, they should be able to communicate. i.e. 192.168.1.x with a subnet mask of 255.255.255.0.
