sturt007
Dec 27, 2018Aspirant
Orbi RBR50 Device List Issues
Hi guys, I have recently bought the Orbi RBR50 with a satilite device. I am having a couple of issues: 1) If I go onto the device list on the Orbi app, I see the devices but if I click to pause...
sturt007
Dec 28, 2018Aspirant
Thank you for the help, that’s great.
With regard to the TP Link router, would you happen to know how I change this to bridge mode? Also, how do I change Orbi to AP mode?
ekhalil
Dec 28, 2018Master
What is the model of the TP-Link Router so I can check how to set it in bridged mode.
For Orbi, you can set it in AP mode using the GUI as follows:
- sturt007Dec 28, 2018Aspirant
The model of the router is: TP Link AC1200.
Thanks heaps for the info on changing Orbi to AP mode, this is now done.
Is it somthing that you would recommend to have the Orbi in AP mode and the TP Link router in bridge mode? Does increase speeds or stability?
Cheers:)
- ekhalilDec 28, 2018Master
sturt007 wrote:
......Is it somthing that you would recommend to have the Orbi in AP mode and the TP Link router in bridge mode? Does increase speeds or stability?
.......Either your ISP router (the TP-Link router) or Orbi should act as the main router in your network. It depends on which device you think has better router functionality. In Orbi the following Router functionality you will loose if setting it in AP mode:
- Guest Network
- QoS
- Setup Wizard
- Port Forwarding/Port Triggering
- Remote Management
- UPnP
- IPv6
- Traffic Meter
- Parental Controls
- Block Sites
- Block Services
- VPN service
- VLAN/IPTV setup
- Internet Setup
- WAN Setup
- LAN Setup
If you think that you need this functionality and this is not provided by the TP-Link router then it's better to keep Orbi in Router Mode and set the TP-Link router to Bridged mode instead.
I don't think that either setting will have any effect on speed.
Ac1200 is just the max throughput of the router. Can't you find any other model number on the box?
Thanks.
On the back of the router, it says Model: AC1200, there is no otger model information.
