RodanThrelos
Oct 22, 2019Tutor
Orbi RBR50 Device Names not Saving
I'm using the RBR50 through my Verizon Router as an AP and I'm trying to change the device names of my connected devices to know which device is which. Initially, when I was setting up the first few...
Rshotok
Oct 23, 2019Aspirant
This is driving me crazy, as I have the same problem.
Oct 23, 2019Guru - Experienced User
Please contact NG and let them know about this:
- singhravikOct 24, 2019GuideAny comment on the satellites dropping wifi connectivity to base? is wifi stanility better on this 2.5.0.38??
- LSStreamOct 24, 2019Guide
I have not noticed any change in stability, although I have not really had any issues with satellites losing connectivity to the base in either wireless or wired backhaul configurations.
- FURRYe38Oct 24, 2019Guru - Experienced User
Please make new post in regards to your RBS now working well and we'll help you out there as this thread is unrelated to your problem.
singhravik wrote:
Any comment on the satellites dropping wifi connectivity to base? is wifi stanility better on this 2.5.0.38??- schornstadtOct 24, 2019Tutor
Same issue here.
- Mac_GNov 21, 2019Aspirant
I've had enough of these updates. Can't edit device names and weird behavior around random access control. Is 2.3.5.30 the best version to revert back to?
- Retired_MemberNov 21, 2019
Mac_G wrote:I've had enough of these updates. Can't edit device names and weird behavior around random access control. Is 2.3.5.30 the best version to revert back to?
I would say yes. Most have had success when reverting back to 2.3.5.30
