RodanThrelos
Oct 22, 2019Tutor
Orbi RBR50 Device Names not Saving
I'm using the RBR50 through my Verizon Router as an AP and I'm trying to change the device names of my connected devices to know which device is which. Initially, when I was setting up the first few...
JMU1998
Oct 25, 2019Luminary
Same issue icons incorrect will not accept changes to icons or names.
Oct 25, 2019Guru - Experienced User
NG is aware of this. You'll have to wait until NG fixes this.
JMU1998 wrote:Same issue icons incorrect will not accept changes to icons or names.
- Fallen_MilkmanOct 28, 2019Tutor
Another company where the community has to be their QA team....
- TizmaselOct 31, 2019Initiate
Same problem here. I updated today then realised something was wrong. Subsequently found this thread. There's clearly a significant bug in this update so why wasn't it pulled earlier?
- Retired_MemberOct 31, 2019
Tizmasel wrote:Same problem here. I updated today then realised something was wrong. Subsequently found this thread. There's clearly a significant bug in this update so why wasn't it pulled earlier?
A better question...why did you upgrade?
