RodanThrelos
Oct 22, 2019Tutor
Orbi RBR50 Device Names not Saving
I'm using the RBR50 through my Verizon Router as an AP and I'm trying to change the device names of my connected devices to know which device is which. Initially, when I was setting up the first few...
Oct 25, 2019Guru - Experienced User
NG is aware of this. You'll have to wait until NG fixes this.
JMU1998 wrote:Same issue icons incorrect will not accept changes to icons or names.
Fallen_Milkman
Oct 28, 2019Tutor
Another company where the community has to be their QA team....
- TizmaselOct 31, 2019Initiate
Same problem here. I updated today then realised something was wrong. Subsequently found this thread. There's clearly a significant bug in this update so why wasn't it pulled earlier?
- Retired_MemberOct 31, 2019
Tizmasel wrote:Same problem here. I updated today then realised something was wrong. Subsequently found this thread. There's clearly a significant bug in this update so why wasn't it pulled earlier?
A better question...why did you upgrade?
Sorry Retired_Member, that's not a better question. It's a pointless question.
- FURRYe38Oct 31, 2019Guru - Experienced User
THe naming of devcies is confirmed and known and NG is aware of it. The impact of naming devices is really not a show stopper and more of an inconveience to users. Doesn't really impact operation or cause the system to fail, thus no reason to pull it.
Users will need to be patient, I presume the next FW update will have a fix.
- LimeyBobNov 02, 2019Aspirant
Lost Device Names and Types in firmware upgrade 20 2.5.0.28 - wont let me change them
I think Netgear you should really take a look at your release testing this is a basic error and could have been easily found.
