RodanThrelos
Oct 22, 2019Tutor
Orbi RBR50 Device Names not Saving
I'm using the RBR50 through my Verizon Router as an AP and I'm trying to change the device names of my connected devices to know which device is which. Initially, when I was setting up the first few...
pablohoney
Nov 21, 2019Luminary
By way of update, email from Netgear support - an admittal of bugs in the latest firmware:
"I just received an update following the logs investigation.
Engineering already found some critical problems in the firmware 2.5.0.38 for both the devices list and also for WiFi stability.
Our development teams are working on releasing a fix as well as run tests on the new firmware.
The actual release plan would aim for early December for the release of said firmware."
