RodanThrelos
Oct 22, 2019Tutor
Orbi RBR50 Device Names not Saving
I'm using the RBR50 through my Verizon Router as an AP and I'm trying to change the device names of my connected devices to know which device is which. Initially, when I was setting up the first few...
DonTav
Nov 21, 2019Aspirant
Does anyone know if NG found a fix for custom device names not saving after V2.5.0.38 firmware update? some names change and some don't??
The App appears to work okay
Nov 21, 2019Guru - Experienced User
Some have said v40 works for them:
If you choose to update, manually download the FW files for the RBS and RBR. Install them then factory reset the RBR and setup from scratch. See if this helps your system.
NG is aware of the problem found in v38 and is working on it:
DonTav wrote:Does anyone know if NG found a fix for custom device names not saving after V2.5.0.38 firmware update? some names change and some don't??
