RodanThrelos
Oct 22, 2019Tutor
Orbi RBR50 Device Names not Saving
I'm using the RBR50 through my Verizon Router as an AP and I'm trying to change the device names of my connected devices to know which device is which. Initially, when I was setting up the first few...
fhammami
Feb 22, 2020Aspirant
Same issue here and also significant drops of connectivity since the last uNgrade to 2.5.0.38.
- tomschmidtFeb 22, 2020Virtuoso
fhammami., if you are still running v2.5.0.38, you should manually update to v2.5.1.8 to fix the issues. Read above for more details.
