Ngearvictim
Mar 19, 2021Guide
Orbi (RBR50) DNS keeps failing.
Hi, I'm have an RBR50 running Firmware V2.7.2.104 that has been working fine for a couple years now. Very recently, devices connected to the Orbi have started getting failed DNS queries, causing th...
- Mar 21, 2021
Ran into this issue as well. This Reddit thread has the best workaround I've found for the bug(s) that Netgear pushed out with its most recent release for this model.
https://www.reddit.com/r/orbi/comments/m5l3vk/orbi_dropping_dns/
There are several options. I think the best one is to use the debug.htm page to enable telnet, log in, and modify the DHCP settings to tell clients to contact external DNS servers directly thus bypassing the failing proxy on the router. This change sticks until the router is rebooted which is rare for me. All devices will renew theri DHCP lease within 24 hours (or less) to get the new setting. I recommend forcing devices to renew their DHCP lease to get the new settings sooner. You can unplug the LAN connection, toggle wifi on/off, reboot a device, or issue the command to renew specific to your device/OS. However if you have one computer plugged directly into a LAN port, one simpler way to reset all the wifi attached device's DNS config is to change the wifi name configured on the Orbi, wait a few minutes, and then change it back. I judged "a few minutes" by monitoring my phone to see when it decided the wifi connection was lost. Once back to the original name, my (Android) phone took a couple of minutes to accept the wifi was stable.
There are also reports that the bug is an interaction issue between the DNS process (dnsmasq) and the traffic measuring/metering feature, and that disabling the traffic measuring feature will avoid the bug. Since I don't *need* the measuring feature, I disabled it just in case a thunderstorm glitches the power, there's a chance the Orbi will remain reliable afterwards without the effort/distraction of the reconfiguration workaround.
ewmgomes
Apr 19, 2021Tutor
I do not understand why this post was tagged as solved... the proposal of downgrading or turning off the NPT or the traffic meter, access by telnet and reboot the DHCP and the DNS service, define the router as AP, and soo on, is not a solution.
The real solution is to having Netgear releasing a new firmware with a final solution for the DNS issue.
There a lot of people with the same issue on different Orbi models (example: https://community.netgear.com/t5/Orbi-AX/Intermittent-DNS-Errors-and-WiFi-Issues/td-p/1950768/ - more than 450 replies and no final solution).
I really want to see Netgear working on this issue, not only the users of the forum.
- FURRYe38Apr 19, 2021Guru - Experienced User
Smething to open a support ticket with NG support if your having problems.
https://www.netgear.com/support/#
Good Luck.
- ewmgomesApr 19, 2021Tutor
FURRYe38 wrote:Smething to open a support ticket with NG support if your having problems.
Good Luck.
Unfortunately it is not an option. I bought this router a couple of years ago and the Netgear only gives me the option to use the forum to have support.
Good Luck.
- bwkeyboardmanApr 19, 2021Initiate
I completely agree with this. Disabling features in a router is not "solving" the problem.
- CrimpOnApr 19, 2021Guru - Experienced User
ewmgomes wrote:I do not understand why this post was tagged as solved... the proposal of downgrading or turning off the NPT or the traffic meter, access by telnet and reboot the DHCP and the DNS service, define the router as AP, and so on, is not a solution.
This appears to be a philosophical issue. Orbi users were frantically dealing with their network use being interrupted every couple of hours and the only thing they could do was reboot the router. The solutions of disabling automatic Daylight Saving Time or disabling Traffic Meter made the problem stop. (Certainly did for me.) We no longer experience the problem. That seems to be the definition of a "solved."
As for getting Netgear to focus attention on the underlying issue, keeping a post "unsolved" on the community forum is not likely to have any effect. My guess is that letters to Netgear's President or Board of Directors would do more to "goose" people into action. Outraged comments on Amazon or wherever the product was purchased, etc.
Also NG offered up a beta for those of you who want to try it out. Contact Blanca_O via PM.
I don't use TM and DST is enabled for my RBK50 system on v104 and beta.
- Ragar99Apr 25, 2021Luminary
CrimpOn wrote:
The solutions of disabling automatic Daylight Saving Time or disabling Traffic Meter made the problem stop. (Certainly did for me.) We no longer experience the problem. That seems to be the definition of a "solved."All you have to do is uncheck DST and the problem goes away? Oh the injustice to the 0.01% that look at logs for having to remember that logs are 1 hour off! Someone needs to file a class action lawsuit against Netgear!
- WillRXRApr 25, 2021Star
I see your point, but since it cripples another function of the Router - ones that folks might like to have, I don't think it's a complete solution. Hence, I'd call it a workaround. Again, I'd say it's Netgear's responsibility to fix this, not their customers.
