ericjooka
Jun 05, 2019Aspirant
ORBI RBR50 dropping connections frequently
I have an Orbi RBR50 with one satellite. I have upgraded to V2.3.1.60 firmware. I have rebooted them both several times. My Wifi connection is sporadically dropping without notice. It resets wit...
Jun 05, 2019Guru - Experienced User
I would power OFF the ISP modem for 1 minute. Factory reset the XR router and power it off. Power ON the ISP modem and let it sync. Then power ON the XR router and walk thru the setup wizard again using a wired PC and a web browser.
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Use Domaintools.com/whois to see where that IP address is coming from.
ericjooka wrote:I have an Orbi RBR50 with one satellite. I have upgraded to V2.3.1.60 firmware. I have rebooted them both several times.
My Wifi connection is sporadically dropping without notice. It resets within 2 to 5 minutes, but I am unable to keep a persistent connection.
I did check the configuration, set the channel to 6, and restarted it all. It ran fine for a few hours, then started again.
I checked the log, and these entries were in there. Is it possible this is causing my problem?[DoS Attack: RST Scan] from source: 88.99.103.29, port 8000, Wednesday, June 05, 2019 14:56:48
[DoS Attack: SYN/ACK Scan] from source: 209.86.93.209, port 110, Wednesday, June 05, 2019 14:47:32
[DoS Attack: RST Scan] from source: 88.99.103.29, port 8000, Wednesday, June 05, 2019 14:47:09
What can I do about this situation?
ericjooka
Jun 11, 2019Aspirant
Thanks FURRYe38
When I first installed the Orbi network, I had disconnect issues. Support was able to help me at that time. Now, I am on my own, since I did not pay for support. I tried to resolve it with a bunch of different recommendations, and nothing worked permanently.
I had two choices. Pay for support and on a regular basis, spend time with support and reconfigure the routers. I chose the alternative - I have replaced my Orbi equipment with a new mesh system from a different vendor. It took minutes to set up and immediately solved the problem.
Installing equipment that requires constant hand-holding and reconfiguration was not what I planned when I bought the Orbi system. Next time I pay big bucks for hardware, I'll read more reviews than the marketing pitches.
