me2yougametruck
Jul 11, 2018Tutor
Orbi RBR50 dropping internet connection constantly
Hello,
On July 4th I purchased my Orbi router on a recommendation from a friend. I previously tried a Linksys AC1900 and it consistently dropped my internet connection (Charter Spectrum). I took ...
me2yougametruck
Jul 13, 2018Tutor
Yes i did see that same post and i changed it to match my local time. Since that time I did have the internet crash once and since talked with my ISP. They are sending a tech out to make sure the modem and lines are working properly. Once that is fixed or confirmed ok i'll update here again. My connection does seem to be a bit more stable so far ( i think/hope) regardless of the modem.
JoCT
Aug 17, 2018Tutor
Any update here? Bought a system with two satellites from Costco a couple of weeks ago and have been having frequent drops just as described here daily. Logs are sort of useless as all I can see is the reinitialization of firmware and then all the DHCP as it reconnects all devices. It seems as if the router actually winds up rebooting although I haven’t confirmed that.
- FURRYe38Aug 17, 2018Guru - Experienced User
What FW is currently loaded?
What is the Mfr and model# of the IP modem the Orbi is connected too?
How is the system configured? Wireless or wired back haul?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
- JoCTAug 17, 2018Tutor
- This is an RBR50 with FW V2.1.4.16, two RBS50 with same FW - wireless backhaul
- Cable Modem: ARRIS DOCSIS 3.0 / PC 1.5 Touchstone Telephony Modem model TM1602AP2
- distance between router and each sattelite is aprox. 50 ft
- not very close to neighbors but I can see their wifi
I had disabled Set 20/40Mhz Coexistence to 40Mhz but I'll try the other suggestions as well.
- me2yougametruckAug 17, 2018Tutor
thankfully and/or fortunately, after all of my researching the issue we found that my darn modem was actually the issue. Took a while to convince my ISP and find the right person who actually checked a few things to determine it was the modem. It's been working fine since then. Had an issue where the modem got stuck in a mode where it was tryign to connect to my old router (or something like that) and once we did a few things they finally determined it had gone bad.
best of luck
