SleeMcDee
Mar 15, 2021Tutor
Orbi RBR50 dropping internet connection. Only coming back up after manually release/renew of WAN IP
My household is running on an Orbi RBR50 (firmware version 2.7.2.104) using a spectrum modem and we are experiencing a drop in our internet connection about 2 - 3 times a day. When the internet is dr...
- Mar 15, 2021
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Be sure to power OFF the modem for 1 minute them back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
Mar 15, 2021Guru - Experienced User
SleeMcDee
Mar 16, 2021Tutor
When we are having these issues with our router I can hard wire directly to the modem and there are no issues with internet connection.
- vajimMar 16, 2021Master
SleeMcDee wrote:When we are having these issues with our router I can hard wire directly to the modem and there are no issues with internet connection.
tell us how long has the problem there?
tell us how you are connected, modem/router, Orbi router, etc.
- SleeMcDeeMar 16, 2021Tutor
We have been having this issue for about 2 months.
Connection path is: Cable modem -> Orbi router -> Gb switch -> Computers
SleeMcDee wrote:We have been having this issue for about 2 months.
OK....looking back at your first post where you mention the firmware, FURRYe38 is one of our firmware experts and should be able to help you.
- FURRYe38Mar 16, 2021Guru - Experienced User
IF there is a router built in at the modem, This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
