DomerIN
Aug 19, 2018Guide
Orbi RBR50 Dropping Internet Connection Regularly
I have an Orbi RBR50 and RBS50 connected via wireless backhaul. They have been working perfectly for a year. For the past two weeks, the router has been dropping the Internet connection regularly, ...
Vengeance
Jan 12, 2019Tutor
Thanks, guys for trying to help, under pressure from my family i cracked down and i put my orbi on the shelf! i bought the deco m9 plus instead!
NightStorm
Jan 14, 2019Guide
Mirrors my experience. I put up with it for a year, trying new firmware, trying beta firmware, resetting, repositioning, reconfiguring, experimenting with power levels, etc. all with a very PO'd family. Enough was enough, I bought the LinkSys Velop, and returned to a setup and just use it system, the way life used to be B.O. (Before Orbi).
- GeegmanJan 29, 2019Aspirant
After no response from support in the first 90 days and another 9 months of resets and configuration manipulation, I finally gave up and replaced with trendnet Ethernet over power access points. Works great and no drops
