DomerIN
Aug 19, 2018Guide
Orbi RBR50 Dropping Internet Connection Regularly
I have an Orbi RBR50 and RBS50 connected via wireless backhaul. They have been working perfectly for a year. For the past two weeks, the router has been dropping the Internet connection regularly, ...
Dalix1978
Apr 24, 2019Aspirant
Hi...
First off, I want to say I agree with you about the level of response. I had the same problem and was getting frustrated reading the copy paste response, especially when multiple times you said they problem wasn’t the Orbi transmitting, but receiving!
anyway, solution I found.
1.) http://orbilogin.com/adv_index.htm
2.) Advance setup
3.) Router / AP mode
4.) select AP mode.
5.) Orbi should automatically reboot, if not reboot.
worked great after this. Seems there was a conflict with my ISP modem/router and Orbi working as a router..
good luck
