DomerIN
Aug 19, 2018Guide
Orbi RBR50 Dropping Internet Connection Regularly
I have an Orbi RBR50 and RBS50 connected via wireless backhaul. They have been working perfectly for a year. For the past two weeks, the router has been dropping the Internet connection regularly, ...
Apr 25, 2019Guru - Experienced User
There is newer FW that may work better.
I got a RBR50 and tested it and it's been working great. Possible configuration issue or environment issue with yours.
The "cut & paste" responses are not pointless. There to help both users and us narrow down problems and help users get there systems working. These "cut & paste" responses not just willy nilly posts. Some of us do have long experinence in working with wifi, routers and troubleshooting and "cut & paste" responses are drawn from our own experineces and knowledge. User are encouraged to give feedback to these "cut & paste" responses. In most cases these "cut & paste" responses do help. If not then users are encouraged to contact NG support and get further help or get there systems RMAd. I've even helped users directly with there systems.
walder wrote:
As mentioned in my previous post I ended up going back to my trusted old router from the Taiwanese firm.
Apart from the pointless cut & paste response from the Netgear team, one of them did PM me asking for additional input ... while i appreciate this I decided not to pursue the Orbi option due to time constraints. I may give it another spin as a pure Access Point when i have the time.
walder
Apr 25, 2019Guide
You may be trying to help but to repeatedly fire 40 questions at someone who has plonked $300-400 on a product that should work perfectly off the bat isn't really on in my view. Most of us on this thread seem to be a minority that are unlucky to have this issue while I am sure Orbi works great for the vast majority of buyers.
If this has helped several unlucky users ... well they haven't come back here to say so.
The Orbi worked great when it did but with the internet unreliability issues it just isn't for me. Perhaps some of those willing to invest the time and effort in experimenting may succeed, and good luck to them. I'm going with something that works for me without having to tinker with settings multiple times a day.
- FURRYe38Apr 25, 2019Guru - Experienced User
Orbi may not be in your best interest. We've helped others and have had good results in some troubleshooting and getting problems solved. I recommend you return the Orbi and get your money back and find something less "cut and paste" for your needs.
Good luck in your endeavours. :smileywink:
The Orbi worked great when it did but with the internet unreliability issues it just isn't for me. Perhaps some of those willing to invest the time and effort in experimenting may succeed, and good luck to them. I'm going with something that works for me without having to tinker with settings multiple times a day.- walderApr 25, 2019GuideThank you. We are both absolutely aligned on this suggestion!
:-) - walderApr 25, 2019GuideBTW, if you are a Netgear support person, I stand by every word I've said. On the other hand if you are not, then my sincere apologies - my comments are directed at Netgear and not at folks who are devoting their time to help fellow users.
Most of us are fellow users here in the forums and not employed by NG. :smileyvery-happy:
