DomerIN
Aug 19, 2018Guide
Orbi RBR50 Dropping Internet Connection Regularly
I have an Orbi RBR50 and RBS50 connected via wireless backhaul. They have been working perfectly for a year. For the past two weeks, the router has been dropping the Internet connection regularly, ...
Jaunty
Apr 27, 2019Aspirant
Thanks for your input, it is appreciated, but I don't see why any of these things should affect the loss of internet connection which is by ethernet from my Virgin Superhub 3 in modem mode to my Orbi router. The incoming Virgin fibre internet connection to the Supehurhub is fine at all times. The wifi connection between the Orbi router and the satellites is fine. All wireless devices show a solid connection and throughput in the Orbi app, they just can't access the internet. A reboot of Orbi reestablishes the internet connection without any other changes, no need to touch my modem at all ever. Enough people have similar problems that I do not want to risk being stuck in this situation after the 30 day return window is up.
ekhalil
Apr 27, 2019Master
Jaunty wrote:
....... A reboot of Orbi reestablishes the internet connection without any other changes, no need to touch my modem at all ever. Enough people have similar problems that I do not want to risk being stuck in this situation after the 30 day return window is up.
I started to have the issue of frequent "freezing internet" from 2.3.0.32 (or actually during the beta 2.3.0.23). It seems that the issue is now solved in 2.3.0.48.
Please upgrade to 2.3.0.48 (if you're not already there).
The data structure in the satellite is changed in 2.3.0.48 so you have to factory reset the satellite (not the router) after upgrading to 2.3.0.48. This is the only time I see it mandatory to factory reset after upgrading. It's strange that Netgear does not mention this explicitly in the release notes.
I have a very stable system since upgrading to 2.0.23.48 a week or so ago. I hope it continues like that.
- amurreyApr 27, 2019Tutor
Reading through these posts, the only people that have successfuly corrected this issue was done via a hardware RMA with Netgear. It's obvious that some percentage of the Orbi devices sold via Costco have a hardware defect that is causing this drop. I RMA'd my router unit 6 months ago now, and the system has been running flawlessly. It's not a setting, its not a configuration, its some type of hardware failure.
- JauntyApr 27, 2019Aspirant
Thanks ekhalil. I am on 48 being one firmware upgrade since out of the box but have not done a factory reset.
- Harryp123Apr 27, 2019Aspirant
I just upgraded to V2.3.1.48 and did factory reset on Router (not satelites).
My router is loosing connection to interenet and restart is fixing the problem before. Since router is causing the problem, I did factory reset on Router only.
- ekhalilApr 27, 2019MasterWhen you loose internet connection does the router top LED turn magenta? Instead of restarting Orbi does disconnecting internet cable and connecting again solve the problem?
no magenta color.
- walderApr 28, 2019Guide
In my experience as well, there was no magenta colour ... i assume all of the LAN including the satellites, remains fully connected. I did not try pulling out the internet cable, but going into the internet config page and saving the settings (without changes) brought back the internet connectivity without restarting the router. My internet is of the PPPoE type, in case this is relevant - so i plug the router directly to my ISP's socket without any modem in between.
For me, the internet service would not drop in one shot for all clients - the clients would progressively lose internet connectivity in random order until none could connect to the internet. The problem did not have any favourites across iOS / Android / Windows and across hardware vendors (Apple, Samsung, OnePlus, Dell)
Also, as an observation, i never got the notification for Circle being offline while clients lost internet connectivity. So i assume the Circle service somehow still remains operational, yet the Orbi does not let clients connect to the internet. Don't see how this should be an hardware issue - presumably this has to do with a unique set of local environment variables including possibly the neighbouring wi-fi networks.
- ekhalilApr 28, 2019Master
walder wrote:
........, but going into the internet config page and saving the settings (without changes) brought back the internet connectivity without restarting the router. .......
What lease time do you have from your ISP? You can find this under >> ADVANCED >> ADVANCED Home >> INTERNET PORT >> CONNECTION STATUS.
- Harryp123Apr 28, 2019Aspirant
Why it says Lease Expires in 1 Hours and 43 Minutes?
Lease Obtained 0 Days, 2 Hours, 0 Minutes Lease Expires 0 Days, 1 Hours, 43 Minutes - walderApr 28, 2019Guide
Sorry i will not be able to answer this straight since the Orbi was decomissioned and now sits in a box. Would it help if i got you the same info from my Asus router which is what i have now?
Yes please. I saw previously that when this time is so long then sometimes Orbi looses the internet connection. We can try to set a shorter lease renewal request time in Orbi as a workaround and see if that can have some improvement.
On the Asus the lease value is 86,400 ... on this i have a daily reboot of the router scheduled for 02:00 so i am not sure if the lease value also gets reset every night. I do not see any lease expiry value.
Lease Obtained 0 Days, 2 Hours, 0 Minutes Lease Expires 0 Days, 1 Hours, 43 Minutes Please try the following to reduce the lease time:
- From browser go to the router's debug page (http://192.168.1.1/debug.htm). Use your router's IP address or http://orbilogin.com/debug.htm
- Enter admin as user name and your router’s management password
- Tick "Enable Telnet" option
- Use Telnet from a computer attached to Orbi to connect to your Router telnet 192.168.1.1 and enter admin and the same password as above
- Enter the following commands:
- root@RBR50:/# config get wan_lease — Should give you --> 86400
- root@RBR50:/# config set wan_lease=750
- root@RBR50:/# config commit
- Harryp123May 02, 2019Aspirant
After upgrading and performing factory reset on the router (4/27), today it dropped connection (5/2). Routine, restarting router worked.
Firmware version: V2.3.1.48
I don't have an option to reduce lease time. Its not editable for me.
- Harryp123May 03, 2019Aspirant
I don't see any logs. Here is the logs after restart router.
[admin login] from source 192.168.1.8, Friday, May 03, 2019 02:59:36
[Time synchronized with NTP server] Friday, May 03, 2019 02:43:01
[Initialized, firmware version: V2.3.1.48] Friday, May 03, 2019 02:42:42 - Harryp123May 04, 2019Aspirant
It dropped connection again and here is the logs:
[DoS Attack: ACK Scan] from source: 18.208.129.192, port 3128, Saturday, May 04, 2019 08:38:38
[DHCP IP: 192.168.1.23] to MAC address 9c:04:eb:82:58:c1, Saturday, May 04, 2019 08:37:44
[DoS Attack: ACK Scan] from source: 18.208.129.192, port 3128, Saturday, May 04, 2019 08:29:28
[DHCP IP: 192.168.1.25] to MAC address 4c:bb:58:41:c7:35, Saturday, May 04, 2019 08:25:50
[DoS Attack: SYN/ACK Scan] from source: 221.204.226.157, port 80, Saturday, May 04, 2019 08:12:09
[DHCP IP: 192.168.1.23] to MAC address 9c:04:eb:82:58:c1, Saturday, May 04, 2019 08:08:21
[DHCP IP: 192.168.1.25] to MAC address 4c:bb:58:41:c7:35, Saturday, May 04, 2019 07:58:40 - FURRYe38May 06, 2019Guru - Experienced User
Can you find out where this IP address is coming from?
18.208.129.192
Domaintools.com
Might ask your ISP to change your WAN IP address on the modem...
[DHCP IP: 192.168.1.25] to MAC address 4c:bb:58:41:c7:35, Saturday, May 04, 2019 07:58:40 - Harryp123May 06, 2019Aspirant
I am not sure how to check where this IP address is coming from. Reg: "18.208.129.192".
Can you please guide me?
Thanks
Inout that IP address here:
- Harryp123May 08, 2019Aspirant
Please find attached "Whois" responses for Dos Attack ip address.
I have seen few of them. This thread not allowing to add multiple files.
Internet connection still dropping.
Today one of the satellite lost connection. I had to unplug power and resync it.
