DomerIN
Aug 19, 2018Guide
Orbi RBR50 Dropping Internet Connection Regularly
I have an Orbi RBR50 and RBS50 connected via wireless backhaul. They have been working perfectly for a year. For the past two weeks, the router has been dropping the Internet connection regularly, ...
May 09, 2019Guru - Experienced User
Wow, he's a winner for sure. :smileylol:
Jaunty
May 11, 2019Aspirant
I don’t want to jinx anything but I haven’t dropped internet connection for a fortnight, running 2.3.1.48, haven’t changed anything since last reboot.....getting 100% of my wired speed over WiFi throughout the house. Fingers crossed long may it continue.
- JauntyMay 11, 2019AspirantI jinxed it. It disconnected from internet for no apparent reason again. 😥
- FURRYe38May 13, 2019Guru - Experienced User
Is the Orbi system operating in Router or AP mode?
I would manually update FW to v60.
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
