DomerIN
Aug 19, 2018Guide
Orbi RBR50 Dropping Internet Connection Regularly
I have an Orbi RBR50 and RBS50 connected via wireless backhaul. They have been working perfectly for a year. For the past two weeks, the router has been dropping the Internet connection regularly, ...
May 31, 2019Guru - Experienced User
Is the Orbi system operating in Router or AP mode?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
is the drop in internet on both wired and wireless devices?
Is the top LED ring on the RBR showing any indication of Magenta when this happens?
Harryp123 wrote:After going through all the steps provided here and upgrading to latest firmware and factory resets, it workes for few days and back to step 1.
During this week, it dropped connection bunch of times, I got frustrated and ready to throw this in trash. What a piece of crap for over $300.
Harryp123
May 31, 2019Aspirant
What is the Mfr and model# of the ISP modem the NG router is connected too? I have Verizon FIOS and its Verizon's modem.
Is the Orbi system operating in Router or AP mode? Router
What is the size of your home? Sq Ft? 3000
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected. Around 30 feet
is the drop in internet on both wired and wireless devices? I think its dropping only Wifi as I don't see my Ooma phone goes to red
Is the top LED ring on the RBR showing any indication of Magenta when this happens? No colors
- Harryp123May 31, 2019Aspirant
Now wifi devices working and my Ooma voip is not working (wired network).
This uncertainty is killing me.
- FURRYe38May 31, 2019Guru - Experienced User
Setup a Reserved IP address for the Ooma device on the RBR. Then input this IP address in to the RBRs DMZ.
Any Wifi Neighbors near by? If so, how many?Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Harryp123 wrote:Now wifi devices working and my Ooma voip is not working (wired network).
Channel 11 for 2.4 GHz
Channel 48 for 5GHz
Any Wifi Neighbors near by? If so, how many? My neighbor and its atleast over 70 feetTry enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).All above settings already set as per suggestion. I performed these steps a while back and they are still same. No changes lately.
