DomerIN
Aug 19, 2018Guide
Orbi RBR50 Dropping Internet Connection Regularly
I have an Orbi RBR50 and RBS50 connected via wireless backhaul. They have been working perfectly for a year. For the past two weeks, the router has been dropping the Internet connection regularly, ...
TonyMcB
Aug 20, 2019Aspirant
Disable ethernet adapter in the network adapter properties and that should stop your wifi from dropping out. I know it sounds like something that you shouldn't do, but that is the only fix for this issue I have found.
- ekhalilAug 22, 2019Master
TonyMcB wrote:Disable ethernet adapter in the network adapter properties and that should stop your wifi from dropping out. I know it sounds like something that you shouldn't do, but that is the only fix for this issue I have found.
TonyMcB , which ethernet adapter do you mean please?
- TonyMcBAug 24, 2019Aspirant
Sorry for the delayed response. I started having the same issue with it again the very next day and I wanted to have a fix before I responded. If you go into the router from a web browser (app wont work for this) than advanced setup, and select wifi settings and at the bottom make sure "Enable Implicit BEAMFORMING - Boosts WiFi speed, reliability, & range for all mobile devices" is unchecked. As soon as I did that everything connects and does not drop out anymore. Hopefully it helps you as it completely has fixed my connection issues.
- FURRYe38Aug 25, 2019Guru - Experienced User
Beamforning is a feature that is recommended to be enabled. It works for others including me.
Had a factory reset and setup from scratch been performed since last FW update?
TonyMcB wrote:Sorry for the delayed response. I started having the same issue with it again the very next day and I wanted to have a fix before I responded. If you go into the router from a web browser (app wont work for this) than advanced setup, and select wifi settings and at the bottom make sure "Enable Implicit BEAMFORMING - Boosts WiFi speed, reliability, & range for all mobile devices" is unchecked. As soon as I did that everything connects and does not drop out anymore. Hopefully it helps you as it completely has fixed my connection issues.
