joel_smith
Apr 28, 2021Tutor
Orbi RBR50 Dropping Internet Connection Regularly
Hi, I have an RBR50 (V2.7.2.104) and two satellites - RBS20 (V2.6.2.104), RBS50 (V2.7.2.104) - in my mesh. The router is connected to the NBN Connection Box: Arris CM8200B Close to every 2 an...
- May 13, 2021
Arggh, I thought I had it with the DNS settings. Apparently not.
But today I have put the ISP modem into faux-bridge mode & connected the Orbi RBR50 to that, so far so good just need to tidy up the network rack now! Below is what I ended up with.
joel_smith
Apr 28, 2021Tutor
Thanks CrimpOn for the validation that the lease time is whack. That said, I thought the Orbi should be bale to handle the lease renewal without complaint???
And also saving my sanity as I tried to find a work around to upload the images.
Attached is the 6 houview of the pingplotter graph.
joel_smith
Apr 28, 2021Tutor
This is the 30 minute view of the ping graph.
- joel_smithApr 28, 2021Tutor
Also, when I connected via the ISP (Optus) issued Sagecmcom Gateway F@st 5366, the reported lease time was 24 hours.
- CrimpOnApr 29, 2021Guru - Experienced User
I'm confused. Is the Orbi connected to a Sagecmcom Gateway F@st 5366 or to an Arris Arris CM8200B?
I forgot to ask if the entire setup has been powered off and back on.
- joel_smithApr 29, 2021Tutor
The Orbi is connected to Arris CM8200B. I connected to the ISP provided Sagecmcom Gateway F@st 5366 as a test only, there were no issues in this configuration.
I think I could power down/up this setup in my sleep now.
Thanks.
- FURRYe38Apr 29, 2021Guru - Experienced User
When your running the PingPlotter test, be sure you are connected directly to the ISP modem first, with out the RBR being online. Test the modem and ISP service line first with a wired PC.
joel_smith- joel_smithApr 29, 2021Tutor
FURRYe38 wrote:When your running the PingPlotter test, be sure you are connected directly to the ISP modem first, with out the RBR being online. Test the modem and ISP service line first with a wired PC.
joel_smithI ran the Pingplotter test with ethernet to laptop direct from connection box & then wifi via the Sagecmcom Gateway F@st 5366, in both instances the Orbi was powered down & no connection issues.
