Tony-OZ
May 14, 2022Aspirant
ORBI RBR50 dropping WiFi - wired connections still OK
Hello Everyone,
My ORBI RBR50 + 1 satellite has started dropping the WiFi service about once every 24 - 48 hours and a reboot is required to get things going again.
I am running the latest firmware v2.7.3.22.
All WiFi devices (iPad's, iPhones, printers, Smart TV's, etc) drop off from WiFI and the similarly the ORBI Satellite also disappears.
My Mac is ethernet connected to the ORBI basestation and it continues to function as per normal and I can browse to ORBI login and look at the logs and finally do a reboot and things are normal after that, until the next WiFi shutdown.
Attached screenshots also show "Wireless Settings: before and after reboot and missing WiFi metrics.
Do the DoS attacks as shown in the logs (see attached) indicate an issue ?
Any suggestions greatly appreciated.
Thanks, Tony.
Latest firmware is 2.7.4.24. I don't know whether it will fix your problem, but it's been working fine for me.
1 Reply
- RocketSquirrelLuminary
