RDLemos
Dec 30, 2017Guide
Orbi RBR50 dropping WiFi Connection constantly ( since 2.1.1.14)
Hello, My RBR50 (+ RBS50) had been working for months without any issue, and I was very happy with the stability and overall performance. Then... I updated the RBR50 (+ RBS50) to v2.1.114, and sin...
- Jan 03, 2018
Hello All,
Update: Issue has been solved
I decided to really look into this issue since it was impossible to get the WiFi stable and the connection dropping with V2.1.1.16 was not an option... (New year resolution... :smileyvery-happy:)
I found out that the issue was caused by a PC connected via ethernet and WiFi simultaneously, and after turning off the PC WiFi, the WiFi (and Router) have been running stable for the last 3 days.
In my case, the problem was caused because I had received a new NUC PC (Win10) just before Christmas, to test a new version of an Conference application from a 3rdParty company (it happens I am a SW developer...) and I had it connected via Ethernet cable to a hub that was connected ( via ethernet cable, as well) to the RBR-50.
The problem was that the WiFi for the same NUC was ON ( factory configuration) so the same PC was connected via WiFi and Ethernet. This was causing havoc with the RBR-50, which would restart ( or kill the WiFi) ~every 30 minutes with V2.1.1.16.The configuration above, should not cause such a problem ( on any router...), and this was a simple Win10 PC. I am not sure if the Conference application ( which works as a local server and must register with a remote server) could cause such problem... but in any case, I just want to provide the feedback to the community here, and maybe the Netgear people may look into such scenario and better protect the router to not cause this issue, or provide some kind of log that would help to debug.
morrisseysb
Dec 31, 2017Apprentice
I think there are a lot of issues with those last two updates. I also have gone back to the .74 version but want to use circle. I am hoping they take their time getting it right this time so while i want to use Circle I also want it to be issue free .
RDLemos
Dec 31, 2017Guide
I have talked too early... I started having the same problems with 2.0.0.74... :smileymad:
I decided to go for a more radical solution:
- I did a factory reset on my RBR50 and then loaded the latest version (2.1.1.16). It started well, but after a while, the problem started again...
I am really frustrated with the reliability of the router.
I had an ASUS RT-N66U for more than 5 years, and several fw updates and never had such problem... I got the Orbi because needed more coverage, but I am starting to regret it... Hopefully, someone from Netgear is monitoring this forum and can help on this matter
- richlin71Jan 01, 2018Initiate
Same problem here - upgraded to 2.1.1.16, then downgraded to V2.0.0.74 and the wifi is dropping out ALL the time. Been like this for a few weeks now while the Netgear engineers are enjoying their vacation. Very frustrating because I've had the Orbi for a few months now and cannot return. It WAS rock solid before upgrading.
- lbdyckJan 01, 2018Star
I am running with the .074 after picking this up the day after Christmas. Initially, all was well and then yesterday my wife told me her laptop couldn't connect. After much futzing around, I got it working. Then this morning I had the same issue on my desktop and the only solution was to power cycle the Orbi main unit.
WHAT is with NETGEAR? I had a NightHawk X6S that I picked up during a black Friday sale and it had a lot of connectivity issues as well - mostly dropping the speed to 25% of the max until a power cycle "fixed" it. Returned it for the Orbi. Now I'm wondering if Netgear is the right vendor but at this point when it works it works well.
Waiting to see what Netgear firmware development does with this after they return from the holidays. I have 30 days to return it if this continues and I did see some nice Linksys units but the reviews on them aren't much better.
- RDLemosJan 03, 2018Guide
Hello All,
- gurpreet2203Jan 31, 2018Initiate
I have the ASUS RT-N66U router and moved last week to Orbi to get coverage all over my house. I am having very frequent connection drops. I do have quite a few 2.4GHz devices which have hard time connecting. So, went back to my old faithful asus to atlease work from home without inernet connection problems.
Did you find any solution to it yet? I am on the latest firmware 2.1.1.18
- jtmegerianFeb 11, 2018Tutor
I have same problem as everyone here. I actually had Netgear replace a router and 2 of my three satellites last month, to no avail. I have replaced my cable modem 3 times in case that was the cause of the problem. I am so frustrated with NG. I tried to ask them to return the system but they told me that is not their policy. I have been on the phone with tech support at the highest levels and all I get is the system to work for a few days before it starts dropping. It always starts slowly, then builds up to drops every 5 minutes. My family is furious, and I work from home and cannot get work done. I actually had to go buy a verizion ellipsis to get a 'backup' network connection for when the Orbi is down. Yesterday, I rebooted the router and there were less drops, but still happening. I am so tired of this and so tired of not getting the fix from Netgear. I have spent over 500.00 on this system. Netgear customer support, if you are listening, please, please please help us.
- gurpreet2203Feb 12, 2018Initiate
I ended up returning the Orbi. And I am Happy that I did. Netgear has the worst customer support ever. Long hold times to get to an executive who just asks you to 'reset the whole system again'. On email support, you get answer only after 24 hours.
After being 'escalated' to L2 support, they will just ask you to 'reset the system' and then ask you to update their beta firmware, as if we are part of their beta testing team! After asking if that will help, L2 Support person says "not really, but lets just try. We have been hearing a lot of comments about these issues in the online coimmunity but nothing has been escalated to their L2 Team yet.' So they are waiting for more customers to be pissed off and return their 'super' expensive equipment 'BECAUSE IT DOES HAVE KNOWN ISSUES'.
Just to let everyone know, I bought Google WiFi and it has been working great till now! I just love google stuff.
