RDLemos
Dec 30, 2017Guide
Orbi RBR50 dropping WiFi Connection constantly ( since 2.1.1.14)
Hello, My RBR50 (+ RBS50) had been working for months without any issue, and I was very happy with the stability and overall performance. Then... I updated the RBR50 (+ RBS50) to v2.1.114, and sin...
- Jan 03, 2018
Hello All,
Update: Issue has been solved
I decided to really look into this issue since it was impossible to get the WiFi stable and the connection dropping with V2.1.1.16 was not an option... (New year resolution... :smileyvery-happy:)
I found out that the issue was caused by a PC connected via ethernet and WiFi simultaneously, and after turning off the PC WiFi, the WiFi (and Router) have been running stable for the last 3 days.
In my case, the problem was caused because I had received a new NUC PC (Win10) just before Christmas, to test a new version of an Conference application from a 3rdParty company (it happens I am a SW developer...) and I had it connected via Ethernet cable to a hub that was connected ( via ethernet cable, as well) to the RBR-50.
The problem was that the WiFi for the same NUC was ON ( factory configuration) so the same PC was connected via WiFi and Ethernet. This was causing havoc with the RBR-50, which would restart ( or kill the WiFi) ~every 30 minutes with V2.1.1.16.The configuration above, should not cause such a problem ( on any router...), and this was a simple Win10 PC. I am not sure if the Conference application ( which works as a local server and must register with a remote server) could cause such problem... but in any case, I just want to provide the feedback to the community here, and maybe the Netgear people may look into such scenario and better protect the router to not cause this issue, or provide some kind of log that would help to debug.
lext
Jan 02, 2018Aspirant
Hi all,
We're having exactly the same problem with the Orbi RBR50: the wifi drops out approximately once an hour. No entries in the logs, it appears to be rebooting itself.
We are running the latest firmware 2.1.1.16, upgrading from 2.1.1.12 last to try to fix the issue, to no avail. It started happening around 2 months ago.
Going to try downgrading the firmware.
lbdyck
Jan 02, 2018Star
Can anyone recommend a stable firmware version?
