RDLemos
Dec 30, 2017Guide
Orbi RBR50 dropping WiFi Connection constantly ( since 2.1.1.14)
Hello, My RBR50 (+ RBS50) had been working for months without any issue, and I was very happy with the stability and overall performance. Then... I updated the RBR50 (+ RBS50) to v2.1.114, and sin...
- Jan 03, 2018
Hello All,
Update: Issue has been solved
I decided to really look into this issue since it was impossible to get the WiFi stable and the connection dropping with V2.1.1.16 was not an option... (New year resolution... :smileyvery-happy:)
I found out that the issue was caused by a PC connected via ethernet and WiFi simultaneously, and after turning off the PC WiFi, the WiFi (and Router) have been running stable for the last 3 days.
In my case, the problem was caused because I had received a new NUC PC (Win10) just before Christmas, to test a new version of an Conference application from a 3rdParty company (it happens I am a SW developer...) and I had it connected via Ethernet cable to a hub that was connected ( via ethernet cable, as well) to the RBR-50.
The problem was that the WiFi for the same NUC was ON ( factory configuration) so the same PC was connected via WiFi and Ethernet. This was causing havoc with the RBR-50, which would restart ( or kill the WiFi) ~every 30 minutes with V2.1.1.16.The configuration above, should not cause such a problem ( on any router...), and this was a simple Win10 PC. I am not sure if the Conference application ( which works as a local server and must register with a remote server) could cause such problem... but in any case, I just want to provide the feedback to the community here, and maybe the Netgear people may look into such scenario and better protect the router to not cause this issue, or provide some kind of log that would help to debug.
jtmegerian
Feb 11, 2018Tutor
I have same problem as everyone here. I actually had Netgear replace a router and 2 of my three satellites last month, to no avail. I have replaced my cable modem 3 times in case that was the cause of the problem. I am so frustrated with NG. I tried to ask them to return the system but they told me that is not their policy. I have been on the phone with tech support at the highest levels and all I get is the system to work for a few days before it starts dropping. It always starts slowly, then builds up to drops every 5 minutes. My family is furious, and I work from home and cannot get work done. I actually had to go buy a verizion ellipsis to get a 'backup' network connection for when the Orbi is down. Yesterday, I rebooted the router and there were less drops, but still happening. I am so tired of this and so tired of not getting the fix from Netgear. I have spent over 500.00 on this system. Netgear customer support, if you are listening, please, please please help us.
veetee
Mar 10, 2018Aspirant
Yes, this is a third time I'm coming back to looking for a solution. I have 1 router and 2 satellites with all the latest firmware and still rebooting them at least 1 or 2 times a day. With $500 spending on this, I just hate to throw them away and go with different solution.
I hope technical support reading this. Here're what I've been monitoring to see if it helps you guys troubleshooting:
1/ My Windows laptop is using DHCP both at home and at work. Certain days, when I came home, a message would come up on my laptop saying "Duplicate IP address". I have to reboot the laptop to resolve it. Please note even if I issue "c:> ipconfig /renew", it didn't help. Please check your code to see how Orbi handling DHCP when a device moving out and in the Orbi wifi network.
2/ I've named 2 of our satellites. When everything worked, under "Attached Devices" menu, it will show which device connected to what satellite. But when certain devices got stuck (please note not all devices got stuck, only couple of them out of about 15 devices I have at home), the menu will show that device connected to a generic name "Orbi satellite". Nothing I can do to bring those devices connected again except rebooting the Orbi router.
Please Please Please help us.
- veeteeMar 10, 2018Aspirant
Another thing, I looked at the "Logs" menu, there's not much to tell if there's a problem. Is there a Troubleshooting logs hidden anywhere that you guys want us to collect? I'll be happy to upload for you guys to examine.
- BnaeveApr 02, 2018Aspirant
I've had the same problems ever since getting this system. Bought it at Costco and took the first one back figuring it was a bad unit. This one is just as bad. Hopefully I can take it back too. The system is completely unstable and NONE of the parental controls ever work. I'm definitely changing brands as I spend more time rebooting the router and trying to get it to work that I do actually USING IT!
Thanks for the advice. I just did a complete factory reset with the latest version (not the beta) a couple of weeks ago. I'll give this a try to get things back up and running but it's super frustrating to have to reset everything. Incredibly time consuming for something that shouldn't be such a pain.
- FURRYe38Apr 02, 2018Guru - Experienced User
What version exactly are you using?
If not v2.1.3.4, Please try the new Beta FW:
After the installation, factory reset the router and satellite then setup from scratch. Use a ethernet wired PC to do the upgrade. Do not apply any saved prior config files. Do a clean set up.
Aspirant2018-04-02 05:15 PMRe: Orbi RBR50 dropping WiFi Connection constantly ( since 2.1.1.14)I've had the same problems ever since getting this system. Bought it at Costco and took the first one back figuring it was a bad unit. This one is just as bad. Hopefully I can take it back too. The system is completely unstable and NONE of the parental controls ever work. I'm definitely changing brands as I spend more time rebooting the router and trying to get it to work that I do actually USING IT!
- veeteeApr 02, 2018Aspirant
Hi,
I just check and I did run with V2.1.3.4 except the RBW30 is running V2.1.2.2. The firmware update tab showing that I'm running all the latest.
However, all the people out there with the dropping issue, I read couple more threads on this issue, one of the recommendation is to disable "Beamforming". I did that and it's noticeable big different for me. The connectivity is a lot more stable now. After you disable "Beamforming", make sure you did all the reset too. It worked for me for the last 2 weeks and I'm continued to monitor and report.
- FURRYe38Apr 03, 2018Guru - Experienced User
Was a factory reset performed when the FW was updated then set up from scratch?
veeteewrote:Hi,
