mxcramer
Jan 27, 2019Guide
Orbi RBR50 dropping wifi connection constantly with 2.2.1.210
Purchased ORBI RBR50 at end of September. Installed and was happy with the performance until the internet started dropping. Between travel and other activities, I was not able to start troubleshootin...
mxcramer
Jan 28, 2019Guide
Hi ekhalil--
Thanks for your response. I could have been more precise in my description.
Indeed, the cable modem appears to be working fine (judging by the lights on the front), but the connection to it goes down. That includes all devices, including devices directly wired to the Orbi or its satellite. Wired devices include iMac (to the Orbi router), as well as Xbox to the satellite.
In my experience, restarting the Orbi is not enough - I have to restart the modem as well to regain access for all my devices.
Mike
Jan 28, 2019Guru - Experienced User
What FW is currently loaded?
Is the Orbi system operating in Router or AP mode?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
mxcramer wrote:
Hi ekhalil--
Mike
