Cavellino33
Aug 27, 2020Aspirant
Orbi RBR50 dropping WiFi flashing white multiple times/day
Multiple times per day my internet drops and Orbi flashes white. Firmware is v2.5.1.16. My wife keeps complaining as if I’m doing it on purpose. Ha. Please help.
Aug 27, 2020Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-router
Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
- Cavellino33Aug 27, 2020AspirantModem is a Motorola surfboard SB6141. One satellite less than 30ft through an uninsulatet sheet rock ceiling in a 2000sq ft house. I tried redoing set up from scratch but problem persists. We do have quite a few WiFi neighbors in the area. I will try your recommendations and see if I have any luck. Thanks
- FURRYe38Aug 27, 2020Guru - Experienced User
If less that 30 feet, still maybe a bit too close. 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
- Cavellino33Aug 28, 2020AspirantI changed all the settings as you recommended but the problem persisted. I was nearly ready to go full “office space” on my Orbi when I decide to unplug the satellite. Unplugging the satellite corrected the problem and WiFi signal has not dropped since. Any ideas on why this happened and how to fix. Satellite is now greater then 30ft from rbr50 but still causing problem
- MstrbigAug 28, 2020Master
What model is your satellite?
Also try resetting the satellite and repair again. I have found sometimes pairing by pressing the pair buttons does not work correctly. So I generally use the app to pair the satellites. Probably doesn't make a difference, but my personal statistics are 60% on button pushing and 100% on using app.
