Cavellino33
Aug 27, 2020Aspirant
Orbi RBR50 dropping WiFi flashing white multiple times/day
Multiple times per day my internet drops and Orbi flashes white. Firmware is v2.5.1.16. My wife keeps complaining as if I’m doing it on purpose. Ha. Please help.
Aug 27, 2020Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-router
Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
Cavellino33
Modem is a Motorola surfboard SB6141. One satellite less than 30ft through an uninsulatet sheet rock ceiling in a 2000sq ft house. I tried redoing set up from scratch but problem persists. We do have quite a few WiFi neighbors in the area. I will try your recommendations and see if I have any luck. Thanks
- FURRYe38Aug 27, 2020Guru - Experienced User
If less that 30 feet, still maybe a bit too close. 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
